DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 10-27-2009, 08:49 PM
mb09 mb09 is offline
Default 96 stratus fuel injection issue help??? :(
Ok so the power steering caught on fire, I fixed the lines, repaired a few damaged wires on the harness, repaired the vaccum lines. I can get it to start after holding the key over, it starts rough. It has fire on all 4 cyl. The connectors on the fuel injectors- 3 read over 12v, but 1 read like 130 mv, could this be my issue? The car back fires and i get some white smoke someone help plz.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-27-2009, 11:14 PM
bad venge's Avatar
bad venge bad venge is offline
Section Moderator
Dodge Forum Moderator
1998 Dodge Avenger
Vehicle: 98 Dodge Avenger
I'd double check te wiring the low one sounds wrong to me ... you can get a noid light and check for power ...but the voltmeter tells the tale
Old 10-27-2009, 11:28 PM
Here is everything that happens, the engine is cold, i crank and crank holding the key over, give it some gas, it wants to die, when the engine warms up a little I am able to rev it up without it dieing. I get backfire in the intake, white smoke, engine is very hesitant to die. I put it in drive hit the gas and it really wants to die.all cylinders are firing and i replaced the connector to the fuel injector. sounds like maybe the wiring is grounding out some where because every time a put a fuse in the interior lights it pops. Would 1 injector not working cause all my problems besides the fuse popping?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
