There is a TSB for this problem. what you need to do is disconnect the oil pressure connector and remove the blank pin going into the connector. and maybe replace oil pressure switch. If the lite stills go on, then replace the oil pump.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
