RE: how to remove governor
ok, number one is the intake plenum. replacing this is helpful, but fairly difficult, and always expensive. Very expensive.
number two is in air intake, common called a cold air intake (CAI) or short ram intake (SRI).
changing to a CAI can boost your horsepower, and while on some cars you may get as much as 15 hp, that is a very high end estimate...expect maybe 5-8, with a K&N filter, on a 3 inch CAI. but this will not help your top speed, since youre governed.
ECU is engine control unit. it is what is governing your car. you would need to get an aftermarket ECU to do away with the speed limiter and they are hundreds, if not thousands of dollars, and on a stock RT, not really worth it.
[IMG]local://upfiles/2745/F2085174FCF14C958D056B4E8FB6253C.jpg[/IMG]
__________________
The New Detroit Autos Examiner!
1972 Dodge Demon 340-1983 Dodge Mirada 340-1992 Plymouth Laser RST-2002 Dodge Stratus R/T Coupe-2006 Dodge Ram 1500 Laramie
