RE: gurgling sound?
its overheating...let it sit until the radiator is cool to the touch, then check the coolant level...also check the coolant resevoir for a dark greenish grey foam...if it is present, you have a bad head gasket...if it is not, i woudl check into the thermostat or a water pump.
__________________
The New Detroit Autos Examiner!
1972 Dodge Demon 340-1983 Dodge Mirada 340-1992 Plymouth Laser RST-2002 Dodge Stratus R/T Coupe-2006 Dodge Ram 1500 Laramie
