Hey everyone, I need some help with my 01 stratus r/t. I got my subs in and working just great but me n all of my buddy's simply CANNOT find the firewall to send the battery wire through for power to my subs. Does ne one know where it is or what otherway i can get to my battery?
thanks
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
Shaun
Sponsored Links
Registered users do not see this ad. Click here to register for free!
I have a 4 gauge wire in my RT, and to do this you will want to begin by opening your hood. youll need to remove your entire stock intake system (i dont have a picture)...youll also have to remove the Left front headlight.
next remove the inner fender well lining. first picture
then remove the piece of plastic that hides the point where the lower side fascia meets the fender. second picture
in the third picture my power line is highlighted in red, it needs to go inside the fender, and to do this, you must remove the left front fender. there are bolts along the top of the engine compartment which is highlighted...BE CAREFUL WHEN REMOVING THE FENDER, IT IS RAZOR SHARP.
now, once the fender is off, you will see a large rubber grommet which is partially under the door and under where the fender was. his is where all of the wires that control the entire car run. you will need to very carefully cut a small slit to feed the wire through. try putting some cooking oil on it to make it easier. when it comes through that grommet, it will come into the car about a foot above the foot rest. i then ran mine under the door sill guard, highlighted in red in the 4th picture. i then removed the rear seat panel, and ran it under there, then under the back of the rear seat, into the trunk..i used a trunk hinge mounting bolt for the ground wire.
this is an awful job. i did it once, and i wil NEVER do it again. have you bypassed the factory amp already?
"you think using gods name in vein is good customer service" "This is Walmart mam and with extra low prices comes not as good customer service" "I want to speak to your manager whats your name?" "roy and im the co manager"
Actually I do have another question. Say I bought another battery to put in my trunk. Would I just but the power from the amp to it and find a ground, or do I need some sort of power from my other battery going to the battery in the back?
i have an 04 sxt sedan, idk how different it is but when i put my subs in the firewall was the hardest thing to do...we punched a bigger hole through the firewall to fit the wire on the drivers side obviously,if u feel around u should be able to tell what it is,u just gotta make it a little bigger....butttt it could be different. let me know
