Stratus 2.4 hesitates from stop
Old 09-28-2010, 02:04 AM
Jesse Novak's Avatar
Jesse Novak
Jesse Novak is offline
Question Stratus 2.4 hesitates from stop
If Im at a stop light and take off, the car stutters and once I get going it falls on its face and picks back up, After 40 MPH its fine. I have changed plugs/wires, installed new camshaft sensor, crankshaft sensor, transmission input and output speed sensors. Put a coil from another 2.4 in it, however the symptoms havent changed. What an I missing??
Old 09-28-2010, 06:41 AM
sapporo's Avatar
sapporo
sapporo is offline
transmission going bad?
Old 10-10-2010, 05:01 PM
goodguy38's Avatar
goodguy38
goodguy38 is offline
out of all the "Techs" here,no one can seem to answer this question...having the same prob.good luck.suppose you have no codes either huh?
Old 12-14-2021, 04:32 PM
Joseph8585's Avatar
Joseph8585
Joseph8585 is offline
Could be fule filter, could be exhaust leak, could be the that air to fuel ratio is off. New injectors or fuel pump my be be needed or Mas airflow
Old 12-16-2021, 09:00 AM
pearl01stratcpe's Avatar
pearl01stratcpe
pearl01stratcpe is offline
You're 10 years too late. That car is probably already crushed and made into something else by now.
Quick Reply: Stratus 2.4 hesitates from stop
