2001 Dodge Stratus RT Coupe Error Code P0507 - DodgeForum.com
Old 03-22-2011, 03:34 AM
da_monk
da_monk is offline
Default 2001 Dodge Stratus RT Coupe Error Code P0507
I recently bought a car from a co worker. When I first got it it needed some work. It had an EGR code. I replaced the EGR and the egr check solenoid circuit. After fixing that the car wouldn't start one day. I replaced the Mass Airflow sensor and it started right back up. After driving it for a while, the car idles high and gives the following code PO507. I brought my car into the shop. First replaced the Idle Air Control Valve. Then I got a rebuilt and reprogrammed ECM. After replacing thses parts I thoguh my code would be gone but it still isn't gone. The dealership and the shop told me that the ECM/PCM takes 300 to 500 miles to relearn what it is suppose to idle at. Im thinking there is either a vacuum leak or the throttle body is messed up. Any help would be appreciated since the shops and dealerships cant even figure it out.
2001 Dodge Stratus RT Coupe V6 3.0 L Mileage: 115,100 miles
Old 03-22-2011, 11:56 AM
rmckellar's Avatar
rmckellar
rmckellar is offline
Try reading this for other options to check:
http://www.obd-codes.com/p0507
Old 03-22-2011, 07:57 PM
pearl01stratcpe
pearl01stratcpe is offline
Your car shares the same engine/chassis with the 2000-2005 Eclipse. Search club3g.com, Im sure a few others have run into this issue.
Related Topics
Thread
Forum
Replies
Last Post
95Ram2500v10
2nd Gen Ram Tech
5
02-01-2016 12:09 AM
V_pecak
Dodge Stratus
1
07-18-2015 11:43 AM
500e
Dodge Charger
1
07-05-2015 11:23 AM
500e
Dodge Charger
0
07-05-2015 11:20 AM
Daug
Dodge Stratus
5
07-04-2015 08:00 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
