DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 11-23-2007, 10:37 AM
mechem mechem is offline
Default RE: facts on the sludge monster
Nice post, valuable info. I've always changed mine regularly. They dont tell you to do it for no reason.
Although 1000% would only make it 50-300w oil. 1000% is basically x10.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-30-2008, 11:59 PM
holtzer1 holtzer1 is offline
Quote:
ORIGINAL: apfootball
well besides penzoil what are some premium oils out there without going synthetic. this is where some opinionated answers come in but id like to know, quaker state, mobil 1, valvoline, what!?!
valvoline valvoline and valvoline.
i've had more engines apart in my lifetime than i care to really think about. i and every other mechanic i've worked with could tell which engines used pennzoil. my 98 t&c has close to or more than 250k on the original engine...valvoline products. after pulling the valve covers to put new gaskets on, there was no clean up rquired. not one spec of sludge or coking. my 2.7 stratus has 70k on it and the insides are spotless. if you really want your 2.7 to last...change oil every2500 miles. small investment for an engine thats known for hitting the graveyard early due to sludge.
__________________
02 stratus es 2.7
08 caravan sxt 3.8
01 ram 2500 CTD
98 town and country
ASE cert master tech, Chrysler cerified tech
Old 07-17-2008, 05:25 AM
Midnight's Avatar
Midnight Midnight is offline
Site Moderator
Dodge Forum ModeratorHall of Fame Member
2004 Dodge Stratus
Vehicle: 2004 Dodge Stratus R/T (3.0L V6)
Send a message via AIM to Midnight Send a message via MSN to Midnight Send a message via Yahoo to Midnight
Link to the post in the Intrepid section: http://dodgeforum.com/forum/dodge-in...e-problem.html
__________________
-Chase
http://www.cardomain.com/ride/3051794
Old 03-11-2009, 10:24 PM
primo382 primo382 is offline
two things... clean oil and a new pcv valve will prevent the sludge monster from residing in your engine. The sludge that forms on the underside of the valve covers is from a pcv system that cannot breathe. Change the oil, and make sure your pcv valve is new. If you think you're sludged up, do not attempt to flush the motor. You'll only cause the 5 pounds of sludge to fall from it's home on the valve covers onto your heads and clog the oil galleries. Remove the valve covers and throw them away... trust me. There is a little metal plate that covers the pcv channel on the inside of the valve cover. Once the gunk gets in there, it is impossible to get it out without removing the plate. Here's the problem, once the plate is removed, there is no way to re-attach it without custom brackets and hardware... all of which must be fastened to plastic. It's not worth the risk when you can find a nice used set on ebay for $50. A small price to pay to keep your intrepid/stratus/lhs from being a beautiful hunk of junk sitting in the driveway until it rots... or worse, you could have strangers out of the newspaper there buying door handles and turn signal switches!
I payed $500 for my 99 trepid that i've put 40,000 miles on. Getting ready to do the timing chain and water pump... it's slapping like an SOB!
Good luck, don't buy into the hype that these 2.7L are ticking time bombs. Oil... regularly!!! Clean the sludge out once and don't let it happen again!
Peace!
Old 04-10-2009, 10:38 PM
joe0121 joe0121 is offline
Send a message via AIM to joe0121 Send a message via Yahoo to joe0121
Quote:
Originally Posted by Newton View Post
The Sludge Monster is only able to survive in spaces equating to 2.7 litres of cubic capacity, and prefers to sleep on an alternating basis in one of 6 cylindrical caves. It's preferred diet are members of the sub-species Moronicus Moronicus, who are found exclusively in the showrooms of Dodge dealerships. The Sludge Monster is known to emit noxious blue smoke when threatened and is known to be particularly afraid of Mobil 1, the toxicology of which is particularly damaging to the Sludge Monster's biological makeup. The only known cure for the bite of this creature is the rapid infusion of 9,000 dollars either in soluble cash or check form, even then, a repeat attack remains likely.
Mobil 1 is good stuff.
__________________
Black 99 Corvette, K&N Intake, LG Pro Long tubes, X-pipe, Cat delete, Basani Cat Back, Comp Cam 407RWHP R.I.P Sep 1998 - 20 Aug 2008 CHECK YOUR TIRE PRESSURE
Red 2002 Dodge Stratus R/T. (3.0L) Short ram intake.
Tags
2005, 27, 37, chrysler, clean, cover, cummins, diesel, dodge, engines, oil, pennzoil, sludge, stratus, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
