1995 stratus no start help
Old 05-04-2012, 02:13 PM
chris3838's Avatar
chris3838
chris3838 is offline
Default 1995 stratus no start help
Hi. I have a 1995 dodge stratus 2.5 liter. I replaced the fuel filter and when i started i noticed it took a little longer to start but did start. Next day car would not start. Checked for codes by doing the key dance and it flashed a 55. Which i believe is no codes. Checked for spark and found no spark. Checked fuel pressure and its at around 50 psi. While cranking the fuel pressure is at just below 50. Any help would be great. Thanks.
Old 05-05-2012, 01:02 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Welcome to DF
No spark could be cause of the crank sensor, or the dist. You could also have a timing belt that broke. You really need a scanner and look at the sensor when trying to start the engine.
Old 05-05-2012, 01:04 AM
SubrinaIsMyCar's Avatar
SubrinaIsMyCar
SubrinaIsMyCar is offline
It may be several different factors... but goodluck with it.
Old 05-05-2012, 06:49 PM
chris3838's Avatar
chris3838
Thanks. Just wish my scanner would work on it. It does obd1 and obd2 but I assume that since its obd1 compliant with an obd2 connector it won't read it.
Quick Reply: 1995 stratus no start help
