dodge stratus brake problem
Old 01-17-2015, 02:54 AM
McMeg1's Avatar
McMeg1
McMeg1 is offline
Mine did the same thing. Had it fixed by a good mecho nic. He said the rear drum brakes were always a bit compressed which made it wear and lose brake pressure. The master cylinder was what I thhough initially as well but turns out that's not the issue. My car had always had a weird gurgling noise in the *** end when I turned it off which I assumed was an aor bubble, it was which was also a brake related issue.
Old 08-02-2015, 09:14 PM
Bluegill1971's Avatar
Bluegill1971
Bluegill1971 is offline
Make sure your rear brake lines haven't collapsed internally. You won't see it from the outside, but inside they might be trashed. It happened to me. I had to replace both lines and cylinders. Then I found that the E brake cable was too rusted to move freely. Good luck.
Quick Reply: dodge stratus brake problem
