DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 09-28-2005, 08:11 PM
acesfull acesfull is offline
Default Need desperate help on 98 stratus
i have had this problem for a while, taken it to 3 different mechanics with out any help. i will be driving the car and check engine light comes on, the car loses power for a moment, light goes off and car again picks up. its not giving any codes. i have changed out the battery, i have changed the fuel pump and filter, still having problem. i recall one time car stalled that NO BUS came out over the odometer. can anyone help?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-28-2005, 11:12 PM
thump186 thump186 is offline
Default RE: Need desperate help on 98 stratus
An itermintent problem will be hard to trace. the old addage holds true that it has to happen to find it. It could be as simple as an o2 sensor to a loose conection or a misfire. when they checked it did they use a code scanner or did the hook it up and do a diagnostic on the system? Most time a scanner will not pull codes from the system if the check engine light is not on.
__________________
Old 09-29-2005, 04:01 PM
from what i have been told they have used both, a code scanner and a diagnostics scan. still up in the air, not sure where to go with it now...
Old 09-30-2005, 03:33 PM
Z28Stratus Z28Stratus is offline
BadStrat is right, a scanner won't tell you the code if the light isn't on. Hopefully the shop can get the light to come on while they are looking at it. Technically when you have a CEL on the engine adjusts the air/fuel ratio and you run a little rich. I'd take the car in immediately after the light comes on if you can. My Accent's CEL is on all the time as I have a bad catylitic converter. But the car still runs decent regardless so I haven't fixed it yet.
__________________
04 Dodge Stratus SE sedan (the family car)
95 Chevy Camaro Z28 5.7L 350 HP/ 380 Ft/lbs. Every bolt on, "built" trans, stall. 18' Z06 rims (the weekend car!)
Old 01-19-2006, 04:47 AM
store6076 store6076 is offline
sounds like an intermittent misfire
should be a history code still stored in the obdII system
even if the light is not on but it will have to be checked by a scanner that can pull history codes or datastream. if you datastream, it will tell you the misfire count per cylinder. check for a bad spark plug wire possibly arcing against something ground in the engine compartment.
Tags
98, diagnostic, plug, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
