DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 09-28-2005, 11:07 PM
g2jant g2jant is offline
Default 95 Stratus Coil Pack Resistance
95 Dodge Stratus, 2.4L DOHC: The Chilton repair manual shows the resistance of the primary coil should be between 0.45-0.65 ohms, I'm getting a measurement of .8 ohms. Is this too high? Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-29-2005, 09:37 PM
Ice_Man_67 Ice_Man_67 is offline
Default RE: 95 Stratus Coil Pack Resistance
i don't see .15 ohms being much of a problem.......the coil is 10 year old isn't it?, probably normal wear and tear/dirt
Does the car run/idle fine?
__________________
1995 Stratus 2.0L 5spd
CAI - w.K&N filter
2.5" exhaust
Magnaflow Cat/Muffler
MSD Coil and Wires
55mm throttle body
AFX underdrive pully
Short Throw Shifter
Canuck Lowering Springs 1.6"
Garrett T3 turbo w/7psi boost
Old 09-30-2005, 01:39 AM
Thanks for the reply Ice_Man_67. No the car does not start at all. I'm not getting any fire out of the coil pack.
Old 09-30-2005, 03:39 AM
well then, get one from a scrap yard.........to make sure thats the prob.
__________________
CAI - w.K&N filter
2.5" exhaust
MSD Coil and Wires
55mm throttle body
Short Throw Shifter
Old 10-29-2005, 09:17 PM
I figured out it was the crankshaft position sensor. I got it to start then found another problem, it has a bad rod bearing. Should I try to replace that one bearing and see what happens? More questions, is that the oil pump underneath the crankshaft and what is the correct way to take it off. Thanks Alot.
Old 10-30-2005, 02:52 AM
brandoncrone brandoncrone is offline
You could try to replace one rod bearing, most likely the crank is shot if the bearing is bad. Does it go away after it warms up?? A lot of 2.0L and 2.4L engines has piston noise on cold starts. The oil pump is on the nose of the crankshaft behind the timing cover, only the pickup is in the pan.
__________________
Dodge/Chrysler/Jeep Technician 14 Years, ASE Master Certfied
1996 Jeep Grand Cherokee Laredo 75,600 miles
1999 Dodge Dakota Sport 318ci 135000 miles
2008 Chrysler Town and Country Limited 2500 miles
Old 11-01-2005, 02:19 AM
I have the oil pan off and can see that it is the rod bearing on the #1 pistion. If it's not the oil pump, then what is that thing underneath the crankshaft with a small chain and sprocket ? Thanks
Old 11-01-2005, 11:06 AM
That would be the balance shaft assembly. Used to reduce engine vibration, nothing more. And it is timed to the crankshaft. Mark the teeth to the chain before you take it off so you can put it back later, if it is out of time you have a bad engine vibration....
__________________
Tags
coil, dodge, pack, resistance, specifications, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
