Engine stuttering or hesitating when accelerating
I have a 2003 Dodge Stratus SE with the 2.4L, 4 cylinder, DOHC engine. Yesterday I was driving normally and I went to accelerate from making a turn and when it got to about 2000 rpms the engine just started stuttering and wouldn't shift into the next gear. I let off the gas a little bit and it finally shifted. This is the problem I have been having now. When you accelerate moderately off of a complete stop the car has a lot of trouble shifting over and it only will do so if you press the gas in slightly. I scanned the car and it came up with a P0340 code which is the camshaft position sensor failure, so I tried replacing it and nothing changed from doing so. I am wondering if it is maybe a wiring failure or something else. If anyone else has had this problem or knows what I can do to fix it it would be appreciated.
I had a very similar issue with my 03 Stratus SXT 2.4L. Same code too, and a misfire code. I would stall out if I tried to accelerate too quick, and it would sputter like all hell, usually forcing me to pull over and turn my car on and off. I replaced the camshaft position sensor, the ignition coil, and changed the spark plug wires + the spark plugs (for good measure). That fixed my issue.
