99 Dodge Stratus - new battery - now quit
Old 07-08-2014, 07:22 PM
dougstractorworksinc's Avatar
dougstractorworksinc is offline
Default 99 Dodge Stratus - new battery - now quit
I have a 99 Dodge Stratus with a 2.0 engine , I had to jump start it yesterday cause of a dead battery , drove it about 20 miles and the batt light came on ; tested the battery and it showed bad so I put a new one in, it started great so took it for a drive and it ran good , then the inside dash lights got bright and it quit ; no fuel pump buzzing , lights all work turns over but no start , now where the mileage numbers show it says = no bus = can someone tell me what happened ? Thanks
Old 07-23-2014, 11:13 PM
StratusMank's Avatar
StratusMank
StratusMank is offline
Check the ignition fuse.
Old 07-24-2014, 08:47 PM
Thanks for the reply ,The fuse was blown in the under hood fuse box , I rechecked all the battery conections they are good - still the -no bus- in the milage box
Old 07-26-2014, 11:16 AM
StratusMank
What do you mean by no bus in the mileage box?
Old 07-26-2014, 12:37 PM
Where the milage numbers are - it will show the numbers , you crank it over to start the engine turns over , let off the key and where the milage numbers show it says - no bus ,
Old 07-27-2014, 01:06 PM
StratusMank
That's a new one. Can't help with that one.
Old 07-27-2014, 04:47 PM
BillS's Avatar
BillS
BillS is offline
no bus is a communication problem between modules and computer could be wiring ,bad cam or crank sensor ,dash cluster or computer, i would first check the battery connections again ,especially the ground to frame are known for going bad or getting corroded ,check connection where it goes into power distribution center (fuse box under hood ),check fuses again just to make sure none blew again, you could try unhooking battery for a little bit and rehooking see if anything changes,try switching out ASD relay under hood with another relay to start ,if none of those help have to start checking sensors,wiring ,computer etc
Old 07-31-2014, 07:27 PM
The car ran great after I put the battery in , the next morning I started it up and after a few miles it started missing , then a couple more miles and the lights got brighter and then it quit , checked all connections etc , asd fuse was blown ,the electric fuel pump doesn't run , if you jump the connctions it does ; I replaced the asd fuse and fuel pump relay ; if it is the ecm , how do I kno it wont just blow it again ? This is really aggravating
Old 08-01-2014, 03:13 PM
StratusMank
Could be an issue with the alternator. When it goes bad, the car will drain the battery for power. How old was the battery that was replaced?
Old 08-02-2014, 07:03 AM
The battery was 4 years old , and it had been doing great until the day I had to jump it twice to get it to the shop , is the regulator in the altinator on these, or in the ecm ? Ill replace the altinator when I do the ecm
Quick Reply: 99 Dodge Stratus - new battery - now quit
