2004 stratus 2.4L ODC codes
Old 03-30-2015, 06:26 PM
PAwrestling#1's Avatar
PAwrestling#1
PAwrestling#1 is offline
Default 2004 stratus 2.4L ODC codes
Can some please help. Just bought a used stratus and the engine light came on. I had 3 codes pop up of which I could only remember 2 of them. P0137 and P0138. The third one I believe was P0562 or P0567. Can anyone tell me what these are and are they all related? What might fix it?
Thanks in advance
Old 03-30-2015, 08:35 PM
BillS's Avatar
BillS
BillS is offline
if you got p0567 that's just cruise control, if you got p0562 that's charging system voltage low . check your battery charge condition ,the cables especially ground off battery, make sure alternator belt is tight ,make sure its charging, codes p0137(low voltage) and p0138(high voltage) to the oxygen sensor the problem may be related to your other code would fix that first ,possible causes of 137 and 138 Faulty Rear Heated Oxygen Sensor Bank 1
- Rear Heated Oxygen Sensor Bank 1 harness is open or shorted
- Rear Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Intake air leaks
- Exhaust gas leaks
- Inappropriate fuel pressure
- Faulty fuel injectors
something I've noticed on here people have more problems with aftermarket sensors then original equipment replacement from dealer
Old 03-31-2015, 06:57 AM
PAwrestling#1
thanks a ton bills
Old 03-31-2015, 07:19 AM
jkeaton is offline
Dodge Forum Administrator
Check here for trouble code meanings.
http://www.obd-codes.com/trouble_codes/
Quick Reply: 2004 stratus 2.4L ODC codes
