04 stratus rt shuts off
Old 04-16-2015, 07:45 AM
robertjferna's Avatar
robertjferna
robertjferna is offline
Default 04 stratus rt shuts off
Hello, Trying to figure why my car shuts off. I have a p0102 code for the maf sensor input voltage low. The car runs fine for about three minutes or so when first started then just shuts off. I will restart it and it will run maybe 5 seconds and die again. I don't know if its shutting off because of temp or not but the gage is in the middle but it does seem a little hot. I just replaced a bunch of stuff on this cap, rotor, plugs both banks valve cover gaskets. I took my time and made sure everything was tight and replaced some questionable vacuum hoses. I did put another maf sensor on it that I got used. If its a low input voltage could I have another sensor that's bad? Any help would be great. Thanks
Quick Reply: 04 stratus rt shuts off
