ABS Lamp light on
Old 05-05-2016, 11:12 AM
Anton Danilov's Avatar
Anton Danilov
Anton Danilov is offline
Default ABS Lamp light on
Hi all,
I have Dodge Stratus 1999 2.5l and ABS lamp is light on after engine start.
And ABS system not working on brake. Also I check resistanse from all sensors and its 2.2kOm and chek power on abs module pins it normal.
Also I connect snapon diagnostic to OBD2 and its cannot connect to ABS module, cannot start pump and solenoids.
So I have a question Does this mean that the control unit is broken? or pump motor is jammed and it has led to that the abs control module is broken?
Best regards!
Old 05-05-2016, 01:25 PM
jkeaton is offline
Dodge Forum Administrator
You need an ABS scan tool to access the ABS system. OBD scanner won't work.
Quick Reply: ABS Lamp light on
