mechanical miss under load only 04 2.7L Help
Hey, I have an 04 stratus with the 2.7 L and it has a miss in the engine only under a load. No codes are coming up, so this is telling me this is a mechanical failure or some gremlin going on in this engine. Any help is appreciated. It has 84,000k on it and it idles great. I don't hear any vacuum leaks or taping. There is no antifreeze in the oil and there's a smell of raw gas in the exhaust. The miss only happens under a load and the more load, like the a/c on and heater blower and lights, the more it misses. Thanks for any help with this.
Not necessarily will it set check engine light on a slight misfire , the rear plugs are a pain you need a real good socket so plug doesn't fall out and 2. 3 inch extensions after you take coil pack off put socket in hole add first 3 inch extension then add second 3 inch extension put wrench on loosen ,fun part have to try and take extensions apart while pulling plug out
Ok..did the full tune up and replaced the valve cover gaskets due to excess oil in the spark plug tubes...didn't help! Ugg...now I have a check engine light for the high input of the tps sensor, must be one of those dodge things that need to be reset or calibrated at the dealer. So much for that...I'm thinking about injectors now. I don't know if there's a port for checking fuel pressure,but this thing seems to be starving for fuel, or that's what it seems like. It runs fine under idle, but when you hit the throttle, it misses until it hits 3 to 4 k on the tach and runs fine. It doesn't seem to have the power it is suppose to have though. Thanks for the help.
