DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 02-11-2006, 02:50 AM
tacoboy tacoboy is offline
Default How do I reinstall crank sprocket??
1997 Stratus 2.0 liter. I have just replaced the crank and camshaft seals and I'm putting everything back together. How do I reinstall the crankshaft sprocket? I have used a piece of PVC pipe, a piece of wood and a hammer to hammer it on thus far but it still has about a half inch to go on the shaft. If I hammer on it more it doesn't seem to go on. If I try to put the bolt in with a spacer, I can't keep the crank from turning and it's useless. Is there a trick to this? Please, if anyone knows, reply quickly! There is snow on the way and I don't have a garage! Thanks!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-11-2006, 03:12 AM
Default RE: How do I reinstall crank sprocket??
One thought I had - should I take my torch to it and heat it up? It's pretty cold outside!
Old 02-11-2006, 03:46 AM
Ice_Man_67 Ice_Man_67 is offline
you may end up warping it...........gotta heat evenly
maybe baking in the old oven as high as it goes........then beat it on with wood, worked for my underdrive pulley quite nicely!
__________________
1995 Stratus 2.0L 5spd
CAI - w.K&N filter
2.5" exhaust
Magnaflow Cat/Muffler
MSD Coil and Wires
55mm throttle body
AFX underdrive pully
Short Throw Shifter
Canuck Lowering Springs 1.6"
Garrett T3 turbo w/7psi boost
Old 02-11-2006, 11:13 PM
OK, I got it. Thanks to another post I read in this forum - for anyone wanting to know this in the future, I put the crank sprocket in a 500 degree oven for about 50 minutes and that did it - I rushed it out to the car and it just slid on - I didn't even need to hammer it! I will do the same for the crankshaft pulley when it comes time to do that.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
