DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 03-03-2006, 03:39 AM
njxc500 njxc500 is offline
Default 2002 Dodge Stratus, BAD IDLE HOT
Hello, and thanks for helping me with this problem. My wife drives a 2002 Dodge Stratus ES with a 3.0 V-6, and this has been a good car, except for the idle. When it is cold, it idles fine. But if you drive somewhere for about 30 minutes, shut it off and go into a store, come back in five minutes, It will start fine, but drop back down to under 500 rpm, it sometimes even stalls. There are a couple things that are odd about this, the slightest touch of the go pedal eliminates the problem, and it ONLY happens when the engine is warm. Please, please the Dodge dealers are worthless on this one. I hear rumors of vapor lock, oxygen sensor problems, or electrical or electronic gremlins. Please give me any input you have. Thanks very much,
Nick
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-03-2006, 04:04 AM
BadStratRT's Avatar
BadStratRT BadStratRT is offline
The DodgeFather
Dodge Forum AdministratorHall of Fame Member
1992 Plymouth Laser
My Garage
Vehicle: 1972 Dodge Demon 340
Send a message via AIM to BadStratRT
Default RE: 2002 Dodge Stratus, BAD IDLE HOT
ok a few things..my car was doing this for a while back it had a bad spark plug..at first, it only did it at idle like when i would start it cold, but as time went on, it got to the point that i could feel it missing at higher rpms. how many miles? and has it ever been tuned up?
__________________
The New Detroit Autos Examiner!
1972 Dodge Demon 340-1983 Dodge Mirada 340-1992 Plymouth Laser RST-2002 Dodge Stratus R/T Coupe-2006 Dodge Ram 1500 Laramie
Old 03-03-2006, 04:13 AM
More info, this happens starting warmed up. It has 57,000 miles on it, and I have done plugs and wires. I really suspected a plug. Didn't change a thing...
Thanks
Old 03-03-2006, 04:38 AM
B_52 B_52 is offline
Sounds like a bad sensor, as most modern cars will start and run on a pre-programmed set of parameters(called Open Loop), until it gets warmed up. During this time the ECU will ignore many sensors. Once operating temps are reached, the ECU will then switch to Closed Loop, and start monitoring all the various sensors.
Could be that one of those sensors is bad. Id guess at o2 or TPS.
I suppose this could be related to a vacuum leak, although my experience saw those type problems more with a cold engine, and vanishes when warm (expansion closed off the leak). Still I would think it possible that expanding metal might expose a leak?
Beyond that, many parts store will go out and check for codes on your ECU for free. Have you had those checked yet?
Maybe someone here can list the correct sensors that are ignored in open vs closed loop?
__________________
I'm not dead yet!
02 Mitsubishi Stratus R/T Coupe
Titanium. Auto.
http://home.wavecable.com/~vtucker/2002_stratus_rt.htm
Old 03-14-2006, 11:44 AM
Would it be possible that an O2 sensor could cause this, they aren't expensive, maybe I should try that.
Nick
Tags
30, dodge, idle, loop, open, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
