RE: 1995 DODGE STRATUS STALLS WHEN WARM
MAYBE your coolant temp sensor is on the way out. check to see if you have any codes. within 5sec turn your key to "run", "off", "run", "off", and "run". watch the check eng light. FLASH..PAUSE..FLASH..FLASH...LOONG pause is code 12: battery discon with in last 50 starts. code 55 is end of codes. good luck.
