DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 08-11-2006, 12:49 AM
Dan1701z Dan1701z is offline
Default 2.5L timing belt replacement
Hi I am trying to change the timing belt on a 2.5L V6 cirrus. I assume theres not much different from the stratus. I need help, I put the new belt on and applied tension, but when I did the timing marks on the cams were off about a tooth. I read online to remove the belt and back the cams up a tooth so that it would line up when tension was applied. When I turned the rear cam it jumped forward like 6-8 teeth then when i turned it back it jumped forward about 6-8 teeth PAST the timing mark. Now I cant get the marks even close together. The cam gear is really hard to turn, is this normal? Please help if anyone knows what I should do.
Thank you very much
Dan
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-12-2006, 12:46 PM
tomthedog tomthedog is offline
Default RE: 2.5L timing belt replacement
the cam is hard to turn 'cause your compressing the valve spings. if it's REAL hard to turn, your valves might be hitting the pistons. lining up the marks can be a real pain, if you can't do it within 6 beers, save it till later. good luck.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
