DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 08-29-2006, 12:10 AM
on7off6 on7off6 is offline
Default Power Windows stopped working
My power windows stopped working on my 03 Stratus. Checked in dash fuse its fine. I don' t know what fuse it would be if it is under the hood. Any thought or suggestion would be great.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-29-2006, 04:53 AM
etbardensxt etbardensxt is offline
Default RE: Power Windows stopped working
Could be a relay located under the hood and by the dash. There is also the fuse by the dash fuse compartment. ALso it could be the switches, depending how often they were used and if little kids played with them. Spilled something on them, that could cause contact problems for the switches. Is it all the windows or just a specific one? If you have four doors, check the rear ones. Every possiblity has to be ruled out or you will be wasting time and money. Switches can cost up to $100, relay or fuses just a couple bucks. The manual and/or the compartment cover will have the fuses and relays labeled.
Edward
Old 08-30-2006, 11:53 AM
All four of the windows are not working. The manuel does not help in pin pointing what fuse or relay it would be.
Thanks for any help,
Rob
Old 08-31-2006, 11:41 AM
tomthedog tomthedog is offline
get a multi-meter from your parts store. you will be able to see where the power is coming from, if your switch is bad, or you have a bad wire. if you have a test light, you should be able to see if you have power to your switch. good luck.
Old 09-06-2006, 01:52 PM
SilverStratus06 SilverStratus06 is offline
Lol do u have the window lock on
__________________
Suter
Old 09-06-2006, 06:11 PM
lock don't keep the drivers switch from working.
Old 09-14-2006, 02:53 PM
ess82198 ess82198 is offline
I have an 01 stratus where all four windows stopped working. I tested all of the fuses and relays and they all checked out fine. I suspected the switch. When I pulled the door panel off, I found the plug came loose. 15 minutes tops. That was the problem for me. Hope it's that simple for you!!!!!!!!! Good luck!!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
