DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 08-30-2006, 06:47 PM
FireFighter2114 FireFighter2114 is offline
Default engine swaping questions and a rotor question
i have a 2002 dodge stratus wanting do a engine swap. mainly becouse my engine has 137 thousand miles on it. And the engine is knocking. I have the 4 cylinder 2.4 liter. And want to know what eninge would be a good swap. i want a 6 cylender 3.2 liter or higher. Also on my stratus my brake rotors keep warping, I'm forced to replace my brakes and rotors every 6 months or so. I'm not heavy on the brakes. Any feed back for eather of these would be apperciated.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-31-2006, 11:50 AM
tomthedog tomthedog is offline
Default RE: engine swaping questions and a rotor question
don't know about the motor. brake fluid soaks up water vapor. if enough water gets into the brake system it can boil and expand causing slight pressure on the brakes. this causes the rotors to heat up too much and warp. try flushing out all the break fluid and replacing it with new fluid. you might (pretty rare) have a problem with the proportiong valve, it regs how much press gets sent to the front/rear brakes. get a bud to help change the brake fluid as brake fluid should be changed every few years anyway + it's the cheapest thing to do first. good luck.
Old 08-31-2006, 07:44 PM
alright ill do that when i replace my brakes and rotors.
Old 09-02-2006, 05:51 PM
shoulda thought about this too. might be time to rebuild the caliper, should be able to find a rebuild kit at your parts store. not hard to do at all. if you have a bad o-ring or packing the brake piston might not be retracking all the way back like it should. good luck.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
