RE: 98 Stratus Starting Difficulty
if can hear the starter turning but the eng don't, your starter is on the way out (bad solenoid). if it takes 1-2 sec for the starter to start turning it may also be the starter. did you change the batt cause it wasn't holding a charge or cause it was old? have you checked the chaging sys to make sure it's working. the prob you discribed could also be a weak batt. good luck.
