RE: Fan Not Blowing on #1 Only
Had this same problem on my 97 on low and medium speeds. It is the blower motor resistor. Mine is mounted by 2 bolts under the glove compartment. It's easy enough to replace yourself if you're willing to investigate where the module is on your particular model year. I actually fixed mine rather than pay for a new one. Mine had 2 resistors that had separated and I joined them again using butt end connectors I had on hand. It worked and has been holding so far.
taco
