DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 11-24-2006, 03:35 PM
Vavavoom Vavavoom is offline
Default Disconnecting battery on '99
Hey all,
I need to clear the codes on my 99 Stratus 2.4L DOHC, and I was told to disconnect the battery. Well, the battery on these is actually behind the front left wheel well, with terminals that run up to under the hood for boosting. How do you disconnect the battery on these in order to clear the codes????
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-28-2006, 02:30 AM
tomthedog tomthedog is offline
Default RE: Disconnecting battery on '99
just pull the pcm/fuel pump fuse overnight, lots simpler. car might run rough for a bit till it gets back online, hope it helps, good lock.
Old 11-28-2006, 10:48 AM
f0x672 f0x672 is offline
Vehicle: 2001 Dakota 3.9l V6 Auto 4x4
Send a message via AIM to f0x672
nah dont plus fuse... just unbolt the negative battery cable from the suspension coil tower.. i think its 15mm.. takes like 10 seconds to do and let it sit overnight
__________________
Quote:
Originally Posted by f0x672 View Post
..$100 a BJ..
Quote:
Originally Posted by rtdakota2001 View Post
yeah, that's pretty steep. next time just go to vegas.
Old 11-28-2006, 12:50 PM
How do I disconnect the negative terminal though? The battery is actually behind the front wheel, it is not under the hood. Will it suffice to just undo the negative terminal that's meant for the booster cables?
And where is the suspension coil tower?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
