RE: defroster smells
well if the heater core had a leak you would either see some anti-freeze on the gound after you shut the car off or you would posibly get some inside the car on the carpets, i believe the passenger side carpet. You would smell it either way but your not. Maybe something crawled in there and is rotting, does it smell real bad or is it just like a faint smell that just gets ya after a while? thats wierd. Does it change if its cold air coming out instead of hot air or does it still smell the same. im lost, very strange, if it were dust it would have cleared up by now, i would take it to the dealer and if it still has a warrenty have then check the wiring and the motor for the defrost fan, maybe thats starting to go or something, good luck
