DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 03-08-2007, 01:04 AM
Volitics Volitics is offline
Default Engine leak problems with Plymouth Breeze (same as Dodge Stratus)
Hello;
I have a 1997 Plymouth Breeze 4-door sedan. The car has about 200,000 miles. The Breeze is the Plymouth version of the Dodge Stratus I think. The cars are essentially the same.
I have had a problem with oil leaks.
- The timing belt cover has had to be repaired for leaking oil.
- I've had to have the head gasket replaced a total of six (6) times. When a new head gasket has been required in the past the engine had started leaking oil.
Now the car has started leaking oil again. It's leaking at the back side of the engine at the passengers side.
AutoZone has pictures and repair information on cylinder heads and timing belt covers. Here are links to the pages:
http://www.autozone.com/servlet/UiBr...3d801ecff4.jsp
http://www.autozone.com/servlet/UiBr...3d801ed093.jsp
Can anybody tell me does the Plymouth Breeze have a tendency to have leaky head gaskets and leaky timing chain covers?
Thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
1997 Plymouth Breeze (same as Dodge Stratus)
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-11-2007, 06:38 AM
tomthedog tomthedog is offline
Default RE: Engine leak problems with Plymouth Breeze (same as Dodge Stratus)
try spraying the eng down at the local car wash. this will help you better see where the oil is comming from. most leaks that are noticed come from the valve cover (top of the eng so it is seen first). you havn't said if it's leaving a puddle or you just see oil on the eng, what's up?
timming cover shouldn't cause oil leaks as it is just a cover, like the hood for the motor(don't have a 4-banger so i could be wrong).
if the head gasket was changed that many times, find a new person to work on your car. the head gasket should be a multi layererd steel (like plywood) gasket. are you sure the head is not warped? if it's the head gasket again it should be done for free. if not call the better buss burr and report the shop. good luck.
Old 03-11-2007, 06:33 PM
Thanks for responding.
The mechanic fixed the problem. I had an oil change the other day. The gasket on the oil drain plug broke. Fortunately, it was minor.
I don't think that it was the timing cover that was leaking. I think that it was the seal around the crankshaft or maybe the camshart that goes through the timing cover that was leaking.
You're right about the head gasket. I have not heard anywhere that the Plymouth Breeze has a tendency to blow head gaskets. The car has got 200,000 miles. But still yet the head gasket should not have to be replaced that many times.
The car runs good. It doesn't seem to be leaking compression or anything. The head may be slightly warped, though. Is there any way to tell?
__________________
Old 03-11-2007, 11:51 PM
skierbri10 skierbri10 is offline
Quote:
ORIGINAL: Volitics
If it is warped, it probably will not run good. Only way to tell is to take apart and look at it.
__________________
Silver 2005 Stratus 2.4l Sedan
Old 03-14-2007, 05:58 PM
sfx_1234 sfx_1234 is offline
To my knowledge I'm not aware of aluminum heads warping. The 2.0 has an aluminum head on it as well as a lot of other parts that are made of aluminum. The engines is a pretty nice engine other than the fact that it's an interferance motor.
Old 07-06-2007, 03:01 PM
aare45 aare45 is offline
Plymouth Breeze/Dodge Stratus 1997 2.0/98kW ,engine like Neon 2.0/98kW? SOHC ?
__________________
http://www3.nationalgeographic.com/places/countries/country_estonia.html?source=G1205
Tags
2007, 97, breeze, cover, dodge, drain, gasket, head, hours, leak, leaks, oil, plug, plymouth, replace, stratus, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
