DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 03-12-2007, 02:25 AM
jimmy1975 jimmy1975 is offline
Default timing belt for '99 stratus 2.4L
i bought myself a '99 stratus in july of 2006, it just turned 121,004 km's on it,
i would like to like to know, when should the timing belt be changed.
i dont drive much, only about 2 km's to work each way mon-friday.
my mechanic says that i can wait till about late spring (end of april/early may) to change it. thanks for any info
james
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-14-2007, 05:53 PM
sfx_1234 sfx_1234 is offline
Default RE: timing belt for '99 stratus 2.4L
The owners manual says to have it done at 100k miles. I did my girlfriends at 101k miles. It was still in pretty good shape. It's better to do it sooner than later if you ask me. Since the engine is an interferance motor if the belt decides to go you'll have pistons slapping into valves and all that fun stuff. If you have the $$$ to get it done when it turns 100k I'd say do it then or even maybe a little sooner. Just start saving now so you have the $$$ to pay for the work to be done if your not doing it yourself. While they are in there it's usually a good idea to change the waterpump as well. Have them check it first to see if its in good shape still. Have them inspect the wheep hole for leaks and also have them check for play in the ceramic bearing in the pump (done by moving it up and down side to side to see if there is play in it or not) If it's nice and tight still leave it in and find a parts store that sells water soluable oil, aka waterpump lube. Add between 3-6oz of that to the cooling system to keep the pump lubricated and see an improvement in the overall cooling of the vehicle. (it also prevents corrosion etc) Also have him check the motor mounts as well. I hope this helps.
Old 03-18-2007, 06:58 AM
tomthedog tomthedog is offline
have the belt checked out. the mech should be able to tell if it's been changed or not, if they can't: find a new shop. when you get the timming belt changed out, change out the water pump and the timming belt tensioner assembley. to change out both of these is about 30-45 min extra work. to hav it done whenever they fail is almost as costly as the timming belt itself, you save LOTS of $$$ as well as having the piece of mind they are good for another 100k.happy motoring.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
