DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 03-19-2007, 03:28 AM
tacoboy tacoboy is offline
Default Oil pooling up in spark plug holes
97 Strat 134k.
I have dealt with this once before - oil that is leaking from the crankcase past the o-rings in the valve head and into the spark plug tunnels - you pull out the wire and it's covered with oil. Back then (about 112k)I replaced the valve cover gasket (which comes with the new o-rings) with an aftermarket part. Seemed OK for a couple of years now the problem is back. I'm getting a misfiring as well and I also had that back then too but I replaced my wires and it seemed to fix it.
What's the deal with this? Do any of you have the same problem?
Can't wait to ditch this car and get a REAL mode of transportation. It's been nothing but a mechanical nightmare since I acquired it almost 3 years ago. I'm nervous to drive it thinking that it's going to strand me (again) in the middle of nowhere.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-19-2007, 04:05 AM
dhvaughan's Avatar
dhvaughan dhvaughan is offline
Vehicle: 01 1500 4wd
Default RE: Oil pooling up in spark plug holes
my son's honda accord does this. last year it began misfiring and we changed the plugs (and drained the oil out of the plug wells, and then ended up replacing the plug wires. i'm not sure if the oil caused one of the plug wires to short through the boot or not.
here's a cheap get by. pull the the wires off, roll up a paper towel and slide down in the well, all the way to the bottom. spray a big shot of carb cleaner down in the well. it will dilute the oil, and the paper towel will absorb it.
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
Old 03-22-2007, 05:45 PM
andym1999 andym1999 is offline
Vehicle: 2000 Stratus SE 2.4L
I noticed the oil in my plug holes as well. I have a 2000 with 139,000 on it. I just haven't changed the valve cover gasket yet. It looks kinda tough to do. Is it something that a person can do on their own???
Old 03-27-2007, 06:24 PM
Yes, but the grommets around the spark plug holes can be a bear. You basically have to ruin the existing ones to get them out.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
