Decal removal
RE: Decal removal
ORIGINAL: northeastern08
Dont just say something is ridiculous...if you do not understand the concept...just ask
RE: Decal removal
You must know a hair dryer does not get hot enough to help anything. A heat gun works, which is the same heat as a tourch gun at a safe distance of course, working in a body shop I certainly hope you know that. In that, you are agreeing with me, so you are calling your own idea ridiculous. On this, I have had enough of your behavior so I am stepping out of this topic. Here is a link to another forum that supports the heat gun and tourch concept as well as some other experiences and knowledge. Note fishing wire is extremely harmful to your paint. I try to add my opinion here and my experience and I appoligize to the original poster. It was not my intention at all to hijack the thread (again this is another reason I step away from threads when they get like this).
http://www.lxforums.com/board/showth...g+door+molding
and bmxox...grow up and read what you write
RE: Decal removal
the easiest way is like some people have said use a piece of floss or fishing line works good cuz it wont break as much as floss does but its up to you. Then just get some adhesive remover and put some on a towel dont just throw it on there and take a the glue residue left behind then just use a littlle bit of wax so it make the paint blend in with the other so it wont be so rough.
