1978 Champion Motorhome
Old 09-25-2004, 01:37 AM
Frankie's Avatar
Frankie
Frankie is offline
Default 1978 Champion Motorhome
I am trying to get an old 1978 Champion motorhome going again. It has been setting up since my dad died in 2001. It has a 440 Dodge engine. I replaced the coil and distributor and got it firing. It will start up and run as long as I pour gas in the carbueretor but will not stay running after the gas burns out of the carbueretor. Seems like it is not getting gas from the gas tank to the carbueretor. I have also replaced the fuel pump. Anyone have any suggestions as to what to do next or any info where I can go for help? Thanks
Old 09-25-2004, 01:48 AM
Frankie's Avatar
Frankie
Frankie is offline
Default RE: 1978 Champion Motorhome
If you would like to you can e-mail me about the above motorhome at Mississippimud01@aol.com
Old 11-13-2004, 11:29 PM
dannysdodge's Avatar
dannysdodge
dannysdodge is offline
fuel filter?
Old 11-14-2004, 12:58 AM
LilMzRam's Avatar
LilMzRam
LilMzRam is offline
Maybe injectors could be bad? I'm no expert at carburetors, but that's another possibility. Eh, just trying to help!
Old 08-19-2005, 01:57 AM
MRG348's Avatar
MRG348
MRG348 is offline
I HAVE THE SAME MOTORHOME, FORST I WAS WONDERING IF YOU HAVE ANY OF THE ORGINAL MANUALS, IS YOU DO CONTACT ME -MRG348@YAHOO.COM- OK NOW FOR YOUR PROBLEM , I HAD SAME PROBLEM, BUT ALSO MY GAS GAUGE DIDN'T WORK, I TOOK OFF MY FRONT GAS TANK ,AND CLEANED IT OUT WITH A WATER HOSE,THEN I WENT TO RAMCHARGERS ,AND BOUGHT A UNIVERSAL SENDING UNIT FOR INSIDE THE TANK WITH A NEW GAUGE TO MOUNT ON THE DASH, WHEN I TOOK OFF THE TANK ,I FOUND A FUEL FILTER MOUNTED ON THE FRAME RAIL NEAR THE TANK,I REPLACED THAT, I ALSO FOUND A FILTER AT THE FUEL PUMP ON THE ENGINE, I REPLACED THAT. NOW I HAVE A PERFECT SYSTEM THAT WORKS FINE , STARTS INSTANTLY. ALSO WHEN YOU FLUSH THE TANK,YOU WILL NOTICE THAT THE TANKS RUST ON THE INSIDE, I USED MURIACTIC ACID TO REMOVE IT ,THEN FLUSHED REALLY GOOD WITH WATER HOSE, DIDN'T GET IT SPOTLESSLY CLEAN,BUT PRETTY GOOD. I THINK THAT IS WHY CHAMPION PUT TWO FILTERS ORIGINALLY WHEN NEW. HOPE THIS HELPS YOU , MRG348
Old 08-19-2005, 02:02 AM
MRG348's Avatar
MRG348
MRG348 is offline
ANYONE INSTALL EXHAUST ON THERE 1978 DODGE MOTORHOME CLASS A , I AM NEEDING ADVICE , ON WHAT THEY DID. I KNOW ABOUT BANKS AND GIBSON SYSTEMS FOR $1000.00 OR SO . ANYONE DO SOMETHING DIFFERENT ? AND GET GREAT RESULTS, PLEASE POST HERE. THANKS,MRG348
Old 08-19-2005, 10:12 AM
Drew's Avatar
Drew
Drew is offline
sounds like the carb could stand a good rebuild.
besides, it sounds as if the float is stuck and keeping the car bowl from getting it's supply of fuel, or the venturi is blocked.
I would first see if your actualy getting fuel to the carb, just pull the line off, set the end of the line in a bowl or cup and put the ignition to run but dont start. if you have fuel it's the carb, if not, the fuel line is clogged.
I would still rebuild the carb anyway
Old 03-17-2006, 12:07 PM
MarioChampion1977's Avatar
MarioChampion1977
MarioChampion1977 is offline
Hi: I have a Dodge Motorhome 1977 30feet I think a Champion looks like a fridge with windows totally square. Some toll me that came with a 440 engine. This motor was sitting for 8 years without started but anually turn arounds. Where I can found the rebuild kit for the carb??. What kind of gas pump use its possible found one in Pep boys or WA??. I know Iam gone to need new spark plugs, ignition cap and rotor, carb kit, gas pump what else please??. If some know if Pep and WA sell this kind of parts. Also I have the rear brake stock where I can find brake shoes, repair kits, lines and brake pump I want to replace all that??. Thanks everybody hope someone can help me.
Quick Reply: 1978 Champion Motorhome
