DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Technical Help & Information > Technical Archives > General Tech
Thread Tools Search this Thread
Old 10-16-2003, 06:33 PM
superbeepete superbeepete is offline
Send a message via AIM to superbeepete
Default 1999 ram 1500 rough idle
i have a 1999 dodge ram 1500 5.9 litre when cold this thing runs real rough till warm have tuned it up rerouted the new spark plug wires to alldata tsb specs no luck not showing a check engine light surges dealer has installed a new fuel pump <IMG src=smileys/smiley6.gif border="0">
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-16-2003, 07:37 PM
dodgefreak dodgefreak is offline
mine was doing the same thing....check the cat or O2 sensors.....though it shouldnt be either unless you have a lot of mile...though your Cat will still be covered under warrenty.
other things would be your Map sensor...or your IAC motor
I would check the IAC motor first though (easier)
pull the IAC motor (located on the back of the TB, held in by 2 #9, I think, torque screws) out of the TB but leave the socket (wires) connected. Have some one turn the key on (but dont start the engine) look to see if the pin moves or not. If it does not move turn the key off and take the IAC out and clean it with carb cleaner....dont push the plunger in your self though, its spring loaded and can be thrown outa wack. Do this on a 'cold' engine to get the full effect. It may be sticking and as the motor warms the plunger may expand thus making it work properly.
The IAC is what controls the idel under different loads (when its cold or hot, or if the A/C is running). The MAP (Manafold Absolute Pressure) is on the front of the TB this also controls Ideling.
__________________
[color=green][i]96' Ram Sport 1500, 5.9 w/
Mopar Performance PCM
Fastman 52mm TB
Edelbrock Headers
Flowmaster 40 series exhaust
Custom "Y" pipe
"Performance Cat"
MAC Air Intake w/ K&N cone filter
with a "Home brew" Ram Air
MSD 6A Ig
Old 10-17-2003, 01:26 AM
dodgewarranty dodgewarranty is offline
Did you have a check engine light with the rough idle? If yes call the dealer ask for the codes and get back to us. There are two tsbs on rough idle/stall. they are both acociated with the IAC (idle air control) so there is a very good posibility he is right. If you need the particulars on them let me know.<IMG src=smileys/smiley16.gif border="0"></P>
__________________
jen
Tags
1500, 1999, 59, 99, cold, dodge, idle, idles, map, ram, rough, ruff, runs, sensor, spec, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
