DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Jeeps
Thread Tools Search this Thread
Old 04-27-2005, 12:49 AM
redriderbob redriderbob is offline
Send a message via AIM to redriderbob Send a message via Yahoo to redriderbob
Default Grand Cherokee's Outside North America 3.0L CRD Engine:
3.0L CRD:
The OM 642 3.0 CRD is a six-cylinder engine with aluminium crankcase and cast-in gray iron cylinder liners. Fuel delivery system features common-rail injection with piezo injectors. Valvetrain features four valves per cylinder with two camshafts per cylinder bank. Turbocharger has variable geometry with electronically adjustable turbine blades assisting in delivering up to 180 bar of peak combustion pressure. Turbocharger also features electronically controlled EGR valve, air intake throttling and swirl control by means of an electronically controlled intake port shut-off. Starting is enhanced by a Quick-Start glow plug system.
Availability Laredo and Limited models:
Type Diesel, common-rail direct injection, six-cylinder, 72-degree V-type
Capacity 3.0L (2987cc/182 cu. in.)
Maximum power 160 kW (218 hp DIN) @ 3800 rpm (53.3 kW/L)
Maximum torque 510 N•m (376 lb.-ft.) @ 1600-2800 rpm
Compression ratio 18.0:1
Bore and stroke 83.0 x 92.0 mm (3.27 x 3.62 in.)
DaimlerChrysler Media
redriderbob
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
2000 Dodge Durango SLT 4X4
Loaded.
2005 Kawasaki KLR650.
http://www.myspace.com/redriderbob
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
