DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > A Blast From the Past > K-Cars
Thread Tools Search this Thread
Old 08-22-2009, 02:46 PM
comp426 comp426 is offline
Angry Rebuilt bottom end 2.2L Turbo So tight will barely turn over without plugs!
Hey there,
I recently had to replace my crankshaft, main, and rod bearings due to the old bearing being eaten after a blown map sensor vac line. Anyway, after putting everything back together, i can barely get the engine to turn over with no plugs in and 2 batteries hooked up, one of which is brand new. During assembly, all the bearings were lubed with oil and everything torqued to spec and then triple checked. To get the engine to turn over i have to cycle the starter several times after which the engine will finally turn. I have gotten it to turn about 5 or 6 times and held it for 10 or 15 seconds but the engine has also failed to produce any oil pressure either. Also, the starter motor died today too, after turning the engine over once with plugs in it.
If it helps, the crank is ground down .010" for both the rod journals and main bearing journals and has Clevite 77 bearings.
How normal is any of this? How long should it take to build oil pressure on a rebuilt engine with new oil and filter just cranking it over? Are there any suggestions as to how i can get the engine to turn over easier, preferably without dropping the oil pan?
Thanks a million for any suggestions!
- Brian
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-26-2009, 11:32 PM
rare aries's Avatar
rare aries rare aries is offline
Keeper of the Ks
Dodge Forum Moderator
1987 Dodge Aries
My Garage
Vehicle: 84 5th Ave, 87 Aries
Send a message via Yahoo to rare aries
Sorry for the late response. This problem has me puzzled too. How tight were the pistons when you put them back in? You should only have to tap them in with a wooden block. If they took a lot of force to re-insert they might be binding up.
__________________
If you're going to f*** up anyway,you might as well f*** up in such a way that it leaves people wondering how in the f*** did you do that??!!
Check out out my latest articles. http://www.examiner.com/x-24688-Albany-Dodge-Examiner
Tags
22, be, bearing, block, bottom, build, cap, chrysler, crankshaft, dodge, end, engine, installation, main, order, pressure, rebuilt, shadow, tight, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
