Quote:
Originally Posted by bubbleboy
Does anyone have any advice for fixng a passenger side water leak on an 89 Aries K? The owner had pressure washed the cowl and engine bay and since then there has been water coming in somewhere leading to water on the pass. side floorboard. We have it in the shop now with the hood off getting ready to abuse sealer, but before that I'd like to hear if any of you have ever had this problem and could lend any advice. Thanx!
we've used the "smoke" machine for checking EVAP system leaks to find waterleaks. Or maybe you could use a trace dye in some water and then UV light to trace back where the leak is comming from.
