K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Can a 2.2 be rebuilt?
Old 12-20-2014, 05:26 PM
firehog's Avatar
firehog
firehog is offline
Default Can a 2.2 be rebuilt?
Got a '84 Dodge Rampage, in pretty good shape except the engine is low on compression 120-120-110-115 and oil pump is worn out or bad bearings, the oil pressure is just up 25% of the dial.
Can you still buy new rings/pistons/valves/bearings /gasket kit for this old of a engine?
If not is there another engine and 5 speed tranny I could drop into the motor compartment to fit to the front drive axle?
Old 12-22-2014, 12:52 PM
smokesxt's Avatar
smokesxt
smokesxt is offline
The 2.2l was very common, parts should be readily available.
Old 12-22-2014, 03:53 PM
firehog's Avatar
firehog
firehog is offline
Default Thanks, just want
to be sure all the parts are available before I take this engine out and have a mechanic put new rings and head job on it. Someone offered me a used 2.2 with around 100K on it for $850 but thought that is too much for an engine with that many miles on it already.
Old 12-23-2014, 07:28 AM
smokesxt's Avatar
smokesxt
smokesxt is offline
I PM'ed you, check that.
Quick Reply: Can a 2.2 be rebuilt?
