Shadow Strut problems
Hi I'm new here. Hoping you can help me with my problem. Strut by KYB, spring cut 1 coil, Moog isolater and bearing. Problem, when I assemble the strut assembly, the bearing rubs against the isolater. All washers top and bottom have been installed. Tried extra washers under bearing in isolater, no difference. Compared other isolaters as well as bearings. All are the same. Orientation of isolater is the same as the stock worn out one. I know the bearing should not rub as it will wear out the isolater as well squeak when turning. Any suggestions? Thanks, John
