broken valve spring
broken valve spring
My 2006 Magnum SRT8 6.1 has a broken valve spring (cylinder no. 8). The engine has run almost 70000 miles.
Fortunately the damage happened when the engine was running idle.
I'm living in The Netherlands where only a handfull of Magnums drive around, the Dodgedealer has never heard of this problem.
That may be, but I've got the impression that these valve springs cause problems more often, also on the 5.7 engines.
My questions:
Does anyone knows more about this problem?
Was there ever a recall (in the US)?
What about the other valve springs?
Thanks in advance, Paul
My questions:
My questions:
My questions:
There was never a recall for that issue on your vehicle. I could find no service bulletins on the issue either.
on
Valve springs were a HUGE issue on the '03 Hemi (5.7) but were changed to stronger ones very early in the '04 builds. Although still not the strongest in the world, unlike the '03s, you don't hear of them breaking that often.
However, it's long been the standard when doing any type of serious power adding mods (heads, cam, etc.) to the 5.7 Hemi, no matter what year engine, the upgrade to 6.1 springs, retainers and pushrods was automatic.
So I'm very surprised you snapped one.
BTW, you came out lucky. The 4.7 HO in my Grand Cherokee dropped a valve seat with 102k on the clock, only idling in the driveway and still took out the piston and both heads. Seat obliterated and ended up going up through the intake manifold and into the other head. I guess I can count myself lucky that the block came out with only one slight scratch in that cylinder wall. Small enough that a quick hone should make it right...
valve into piston head
All theories aside: An image is better than a thousand words.
Whatever seemed to initiate this (valve spring, valve seat, overheating, no lubricants) this valve is now inside the piston head of cylinder number eight. According to the mechanics, there is no other cause tnan a broken valve.
My questions:
My questions:
I just picked up my 2010 Dodge Challenger SRT8 from the dealership that was diagnosed with a bad valve seat when cylinder #8 misfired 2 months ago. It took two months because there seems to be a shortage on cylinder heads for the 6.1. When the head was pulled, the Tech discovered that the valve spring was also broken. Fortunately nothing else was damaged, so the spring was replaced and new head installed.
Trending Topics
