So i go out to my car a few days ago and start her up and try to put her in gear and it is a no go. It feel like the Clutch is not fully disengaging. I check the fluid in the cylinder, Tried to bleed the slave cylinder and adjust the pedal. all of these things didnt make a difference. Could it be a bad slave cylinder? .With the car off the shifter goes into all gears smoothly.I have an aftermarket clutch by Darrel Cox Racing, it has been in for about 4 months now. Anyone know anything????
Thanks,
Paul
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
E1 Turbo-Maxx Fab 3in O2-PSI CAI-PSI Dog Bones-AEM Wideband -MSD Wires -IPP Coilovers-ED WUSS IC -MPx 3in TB No Cat-55MM DCR TB-MOPAR Stage 2 w Toys-Rev it up Trac B-Apexi TT-Mopar STS-CBD B&C pillars & License plate-Upgraded Sways
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Im not to sure, but maybe the pressure plate may be bad, i have a simaler problem, but it was my pedal, and the dealer told me that my pressure plate was bad, so im not to sure try that, if not good luck, but to me its sounds that the aftermarket clutch is bad as well, or that they did install it right.
my car does that wen i try and drive it after it has been sitting overnite, its very hard to get into gear for the first 10min. and as i drive it and it warms up it starts shifting normal. im getting a new clutch putinonmonday so hopefully that will fix it...
Just a little update on this. I did figure out what was wrong and it was kinda simple the pressure plate bolts werent tight. So just tightend them up throught the inspection hole and everything is great now!
__________________
