DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > SRT Forums > Neon SRT-4
Neon SRT-4 Dodge Neon SRT-4 is the pocket rocket that took the import scene and turned it upside down. The Dodge Neon SRT-4.
Thread Tools Search this Thread
Old 09-29-2008, 03:54 PM
STILL GH3TtO STILL GH3TtO is offline
Default Fog light question
Where can I get a set of hid foglights.??
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
agp ball bearing 50 trim, RC 750cc inj.,fuel return line, d-tec fcbc, turbo back b&b, husrt sts, big fmic, hks ssqv, warlboro fuel pump, agp 3' cai. Ksport 36 way coilovers
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-29-2008, 05:34 PM
PSI Chick PSI Chick is offline
2003 Dodge SRT-4
Send a message via AIM to PSI Chick
a few companies make them. they're VERY expensive though because you have to replace the housing as well as the bulbs and ballasts. i think it's something like $350 or so. prolumen made a kit, not sure if they still make them. i don't know what vendors sell them, try mpx or turboneon store.
__________________
www.iamletired.com <------ join me!
Old 10-06-2008, 07:28 PM
Moparmatt440's Avatar
Moparmatt440 Moparmatt440 is offline
Vehicle: 04 SRT-4
If you are looking at just getting bulbs, you dont need a new houseing, that only if you want projector style. http://www.wholesalexenonhid.com has the HID kits for $88, its the bulds and ballast and what ever level you want I have 8000K on both my head lights and fog, nice and bright
__________________
Old set up: dyno 303hp, 388 tqr w/ S2, full bolt ons and race gas+meth
Old 10-07-2008, 02:55 AM
will they just mount into my stock foglights? Do you know what one off that list I need?
__________________
Old 10-09-2008, 12:08 AM
Vehicle: 04 SRT-4
Yea the drive/fog lights are the 899 models and the headlights are 9007, last time I checked they were out of the dual filament HID bulbs, they do have just have a low beal one. They plug right into the stock hole, they will have two wires that just plug into the factory harness, and another that goes to the ballast. HID's are way better due to the fact that they only need 35watts to run were as the normal or after market bulbs non HID need 55-65 watts, so your electrical system wont have to put out as much this sending more juice to needed areas.
__________________
Old 10-12-2008, 08:39 AM
LilSparkPlug's Avatar
LilSparkPlug LilSparkPlug is offline
Vehicle: 2004 Dodge SRT-4 (AAR)
Send a message via AIM to LilSparkPlug
MoparMatt that is entirely false information and misleading. Yes they are 35 watts, but thats running wattage not start-up. HIDS on a stock wiring system that is meant to handle 55w for headlights and 27.5 watts for foglights can cause a fire in your multifunction switch (or melt it, its happened to LOTS of people). You NEED to run a relay harness! Why? HIDS require over 50,000 volts of power to ignite the gas inside the bulbs, your factory electrical system was not built to handle that extreme voltage. If you want to run HID headlights and foglights, you'll need two relay harnesses. You can find them on ebay and plenty of other places carry them.
Headlights are 9007
Foglights are 899/893
You can put an HID bulb in your stock foglight housing, but it will throw light everywhere since there is no projector to concentrate the beam. What is optimal is buying projector foglights, there are some on ebay for around $100 shipped, and then buying the proper bulb kit for those. Mine are an H3 bulb. Its safer for other drivers as well since you aren't blinding them with randomly dispersed lighting.
__________________
MySpace
Tags
2004, assembly, ballast, bulbs, dakota, dodge, fog, headlight, hid, hids, light, put, ram, relay, running, srt4, stock, watts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
