RE: NEED help on oil can catcher & TT installation
first off, did your catch can came w/ everything you need to do the installation? ( you need two hoses size 3/8" and clamps.) if so ,then look for the PCV valve right next to the oil cap.disconnect the stock PCV hose and connect one of the hose provided to the pcv valve and the other end to the catch can.then connect the other hose that is provided to the catch can and the other end to the intake manifold. you can mount the catch can anywhere you can find a room. most people w/ aftermarket catch can (like a greddy )mounts it right next to the collant overflow.
