Need help with an Install?? Check here before you post: **FIXED 10/22/05**
I take no credit for these installs, these are simply links posted to assist you guys in installing different parts for your SRT-4. Feel free to post up any extra links that may help people out that I have forgotten. Please do not ask questions about the installs here, post an extra thread in the forum if you have a specific question
RE: Need help with an Install?? Check here before you post:
Question: My '05 SRT seems to have a miss when if I floor it at 2600 rpm in 5th, is this normal as there is a lean condition? Or are these motors hard on plug wires or are they really sensitive to RPM till boost comes in? Also what should the boost guage max at? Mine goes to 11+ #'s
i've hit 19lbs on mine..holding around 15 ish..all depends on your setup, stock or do u have a wastegate or exhaust work..all depends
__________________
03 SRT-4 Flame Red
stage 2 with toys
Mopar sts
Borla exhaust
Mopar tail lights
Fiber Images hood
Motegi FF6's
KW stainless adjustable coilovers
All Booger bushings
K&N CAI
Mopar blow off valve
2700 MILES..it actually still has the n
changing stock springs to lowering springs is easy. tools needed is a spring compressor, 3/8 drive ratchet with socket sizes, 13mm,21mm, 19mm,. you take the 3 top hat bols out and then remove the wheel then take the 2 bolts out that connect the strut to the knuckle. compress the spring and change... same thing on all 4 struts. (back have to remove sway bar)
__________________
TUNED BY... UNIQUE DESIGNS
Custom Powder Coating and Polishing..
please tell me what mods you have done to your car. i can help you figure it out....
__________________
