Boost Problems
Old 10-06-2016, 08:55 AM
StormTroppersrt4's Avatar
StormTroppersrt4
StormTroppersrt4 is offline
Default Boost Problems
MY 04 srt is having some problems, the person that had this car before me tried to bypass the boost solenoid and its only boosting to 4-5 psi so I believe its on wastegate spring pressure, also I have a BOV and and I believe stage 1 fuel system but when I start my car cold or it hasn't been run in a few hours it just cranks for a long time then it will kinda stutter but then starts right up. also my fuel regulator reads over 65 all the time and but my ECU shoot a system lean code. Could I run and new wastegate and a higher psi spring to control boost rather than the solenoids or what should I do. I have a diablo sport too.
Quick Reply: Boost Problems
