Help P0440 cell.
Old 03-08-2017, 08:49 PM
BlitzKizer497's Avatar
BlitzKizer497
BlitzKizer497 is offline
Default Help P0440 cell.
Switched the purge solinoid and gas cap and it keeps comming back. Any advice please.
Old 03-09-2017, 08:13 AM
jkeaton is online now
Dodge Forum Administrator
Here's some more ideas to try.
https://www.obd-codes.com/p0440
Old 03-09-2017, 01:23 PM
BlitzKizer497
I'll try buying a new canister. Thanks
Old 03-11-2017, 09:09 AM
BlitzKizer497
Still didn't work. >.> I was told that the pcm is getting a ground signal so it's not doing what it's supposed to do correctly. I don't know if I should buy a new pcm or test the wires
Old 03-11-2017, 10:28 AM
primem's Avatar
primem
primem is offline
did the evap canister come with a Natural Vacuum Leak Detection assembly?
the valve in the assembly seals the system and a vacuum sensitive switch closes and sends a signal to the pcm.
if the pcm isn't seeing the switch close, the possible causes are:
-system leak
-nvld valve stuck open
-vacuum switch stuck open or closed
-open circuit in the wiring from the switch to the pcm.
-blocked purge vacuum path
if you have a scan tool and hand held vacuum pump; its pretty easy to test the operation of the switch. maybe the switch is stuck closed
I'm surprised your getting a fault in the winter as the test is inhibited in temps below 39*F
