Brake Issue 2001 Ram 1500 4WD
Old 07-22-2014, 12:32 PM
Tony T's Avatar
Tony T
Tony T is offline
New Member
Default Brake Issue 2001 Ram 1500 4WD
On my 2001 Dodge Ram 1500 4WD Quad Cab, I noticed a grinding and scraping sound from the front right wheel about a week ago. Upon inspection I noticed that the retaining clip on the top of the caliper had worked out far enough to be scraping against the rim. The scraping from the retainer had left a noticeable grove in the inside of the rim. So I replaced the top and bottom retaining clips. With in two days the top retaining clip had worked out again and started to cut into the rim again. I replaced the brake pads and rotor less then 6 months ago. I've seen others online having this same issue but can't find out how to fix it. Any Ideas?
Old 07-22-2014, 12:33 PM
djbucky3's Avatar
djbucky3
djbucky3 is offline
Go post in the 2nd gen ram section, more help will be there!
Welcome to DF
Old 07-22-2014, 12:59 PM
Tony T's Avatar
Tony T
Tony T is offline
New Member
thank you
Old 07-22-2014, 01:57 PM
jkeaton is offline
Dodge Forum Administrator
Since you started a new thread in the 2nd gen Ram section. This thread is closed.
Quick Reply: Brake Issue 2001 Ram 1500 4WD
