A/c electrical problem
I am not getting power to the ac clutch. Fuse is good and indicated light on switch is lit. What do I look for next?
2006 ram 2500 with 5.9 diesel. Low side pressure is 80 psi. Do not know location of low pressure cut out.
First thing you need to do is state what vehicle you are having issues with. Probably low on refrigerant but really can't say until you add a lot more detail.
Read this: https://dodgeforum.com/forum/1st-gen...our-visit.html
Yes. The compressor is not getting power. The fuse is good, and I do not know where the low pressure switch is located Could it have gone bad or is there something else I need to check?
Probably wanna post in the 3rd gen ram section. Folks there should be able to point you in the right direction.
