Non-Dodge Members Rides Do you have a non-Dodge that youd like to show off on the forum? This is the place to post information about your nonner!
where to locate a run only Wire from ignition?
Old 08-05-2011, 11:08 AM
Gasmiser's Avatar
Gasmiser
Gasmiser is offline
Default where to locate a run only Wire from ignition?
I,m field testing a Hydrogen dry cell generator for my PT Cruiser 2008 and need a little help locating a run only wire from the ignition so that when the engine is running that the generator can only be on if the motor is running.Can anyone locate this wire so I can install this generator this weekend and start posting results each week here.I currently get 27-31 mpg w/o a/c with ac 22-15 mpg now.
Old 08-09-2011, 11:40 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
You can look at any Haynes or Chiltons manual for the electrical schematics and find or or get a test light and probe your wires for power on with the key on and power off with the key off
Quick Reply: where to locate a run only Wire from ignition?
