The following is an accident report of a construction worker who was injured while working on a newly constructed building. It was reported in Australian Workman’s Compensation magazine.
Dear Sir:
I am writing in response to your request for additional information in Block 3 of the accident report form. I put ”poor planning” as the cause of my accident. You asked for a fuller explanation and I trust the following details will be sufficient.
I am a bricklayer by trade. On the day of the accident, I was working alone on the roof of a new six story building. When I completed my work, I found that I had some bricks left over which, when weighed later were found to be slightly in excess of 500 pounds.
Rather than carry the bricks down by hand, I decided to lower them in a barrel by using a pulley, which was attached to the side of the building on the sixth floor. Securing the rope at ground level, I went up on the roof, swung the barrel out and loaded the bricks into it. Then I went down and untied the rope, holding it tightly to ensure a slow descent of the bricks.
You will note in Block 11 of the accident report form that I weigh 175 lbs. Due to my surprise at being jerked off the ground so suddenly, I lost my presence of mind and forgot to let go of the rope. Needless to say, I proceeded at a rapid rate up the side of the building.
In the vicinity of the third floor, I met the barrel which was now proceeding downward at an equally impressive speed. This explained the fractured skull, minor abrasions, and broken collarbone, as listed in section 3 of the accident report form.
Slowed only slightly, I continued my rapid ascent, not stopping until the fingers of my right hand were two knuckles deep into the pulley. Fortunately by this time I had regained my presence of mind and was able to hold tightly to the rope, in spite of beginning to experience a great deal of pain.
At approximately the same time, however, the barrel of bricks hit the ground and the bottom fell out of the barrel. Now devoid of the weight of the bricks, that barrel weighed approximately 50 lbs. I refer you again to my weight. As you can imagine, I began a rapid descent, down the side of the building.
In the vicinity of the third floor, I met the barrel coming up. This accounts for the two fractured ankles, broken tooth, and several lacerations of my legs and lower body. Here, my luck began to change slightly. The encounter with the barrel seemed to slow me enough to lessen my injuries when I fell into a pile of bricks and fortunately only three vertebrae were cracked.
I am sorry to report, however, as I lay there on the pile of bricks, in pain, unable to move, I again lost my presence of mind and let go of the rope and I lay there watching the empty barrel begin its journey back down onto me. This explains the two broken legs.
I hope this answers your inquiry.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
-1995 Isuzu Rodeo
31x10.50x15 BFGoodrich All Terrain's
Rancho RS5000's
Sponsored Links
Registered users do not see this ad. Click here to register for free!
sounds like somthing that would happen in a cartoon
__________________
"you think using gods name in vein is good customer service" "This is Walmart mam and with extra low prices comes not as good customer service" "I want to speak to your manager whats your name?" "roy and im the co manager"
__________________
2000 Dodge Durango RT
Powerdyne Supercharger
MSD Ignition & Coil
Superior Air Airhat
20" Coddingtons Wrapped in
Perelli Scorpion Assemetrico Zero
Fastman 53mm TB
Custom ECM from B&G Chrysler
